[Audio] Subwoofers Neufs et Occasions
James
MessagePosté le: 14 Oct 2006 18:23    Sujet du message: [Audio] Subwoofers Neufs et Occasions Répondre en citant
Caisson + Subwoofer 28CM Phoenix Gold
99 €
Subwoofer AVI
25CM ou 28 CM
ABSOLUMENT NEUF dans la boîte !
SL200
The SL Series subwoofers have been a very strong line since the beginning of AVI. It has gone through over 5 generations of modifications in the past 10 years. Today, this line is just as popular as when it was first sold, because they are still the most powerful and highest sound quality subs on the market. However, their intended use is strictly for ported enclosures or bandpass boxes.
T/S DATA Znom 42 Ω Revc 3.1 Ω Fo 39 Hz
Sd 0.025 M2 (38.76 in2) Le 0.832 mH SPL 90 dB
Xmax 3.75 mm (0.15 in) Qms 7.015 BL 9.46 TM
Vas 26.83 L (0.95 ft3) Qes 0.34 Pnom 200 W
Cms 412.5 µm/N Qts 0.324 Pmax 400 W
PERFORMANCE 33 to 1850 Hz at -10 dB points, in optimum vented enclosure.
52 to 700 Hz at -3 dB points, in optimum vented enclosure.
400 watts music program material.
200 watts AES pink noise rating.
90 dB average, at 1 watt and 1 meter, in half space.
4 ohm nominal, 3.1 ohm minimum
PRIX 350 € Pièce ! Vendu à 100 € ILS SONT NEUFS dans la boîte !!!
Plusieurs modèles disponibles
www.avisound.com ( aller voir la qualitée )
